Hey guys just wanting to no if anyone has used the bowral brown brick or gertrudis brown bricks for their home? If so is the quality of them good? Any problems? Thanks
Browse Forums General Discussion Re: Bowral brown or gertrudis brown bricks? 7Sep 03, 2014 1:30 pm Jayjay84 Thank you so much for the info we have decided to go with Gertrudis Brown we have just finish going around looking at the bricks on homes and the only thing we are worried about is the grout with the flush finish we think it looks a bit messy do you think raked grout will look good? Were building with Bowral Murray Grey and though along the same lines, looked at using flush mortar finish. It took me a lot of research to find that Bowral bricks re reccomended with an Ironed Finish. It's more of a rolled look and makes the brick stand out a little better. Originally I had specified flush, but have changed to ironed. I would look into an Ironed finish and see if you like that. You want the brick to be the focal point first, not the grout. Btw I would double check your grout color, an off-white mortar would set those bricks off nicely. DIY, Home Maintenance & Repair to do it properly you need to dig out the garden and waterproof the outside of the wall. There are some products you can put on the face of the bricks but the water is… 2 4613 Hi All, Recently we have signed a contract with Burbank and we are not aware that they have just DORSET, SURREY, HAMPSHIRE, KENT, PILBARA and REDGUM bricks from PGH are… 0 3131 |
