Browse Forums General Discussion Re: Brick Infill above windows and doors?? 21Oct 08, 2008 6:48 am The only problem with that is if there is a doorway - hinged or sliding door etc, the head height doesn't match unless you have a non standard sizing. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10934 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5243 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 20616 |
