Browse Forums General Discussion 1 Aug 19, 2014 2:13 am Hi, Need some opinions regarding single vs double story homes. I have bought a +- 600m2 corner lot(minimal traffic) in WA. The front faces west towards the ocean which is about 2km away. The block has a 2m slope over 30m from front to back(being higher at the back). From what I can see from the different builders' websites (and my budget), I can either go for a very entry level double story house, or get a single story with alot of inclusions like 31c ceilings etc etc. entry 2story vs very upgraded single story. I might have glimpse of ocean if i go single, if i go double i will definitely have some ocean view. Any advice would be appreciated Re: Opinion: Single or Double 3Aug 19, 2014 12:05 pm I agree, I generally much prefer single storey houses but to get a view I would certainly go the double. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Opinion: Single or Double 4Aug 19, 2014 1:23 pm Why not see about going split level due to the slopes on your block... but I don't think you will find a volume builder that does that, it would need to be a boutique builder My build: viewtopic.php?f=31&t=68002 Re: Opinion: Single or Double 5Aug 19, 2014 3:24 pm Thanks for the input thus far. Other people on same street for example went with Aveling builders which put 4 splits in - but I believe the siteworks is pretty expensive, which leads me to wonder how much siteworks will be on a single vs double story. as the base will be smaller on double. Re: Opinion: Single or Double 6Aug 19, 2014 6:13 pm In my opinion, I think it depends on the value of houses/median around your area. If the median of houses around your area is for example $500k and you build a house worth $1 million, you might find it hard to sell your house later down the road. Double storey would cost a lot more especially in WA since it's double bricks. I am currently building a double storey and everything that has to do with a double storey cost more. For example, the starting price of smart wiring packages for double storey is higher even though you get the same thing as a single storey. Same thing with putting in air conditioning. At the end of the day, everything adds up.... Re: Opinion: Single or Double 7Aug 19, 2014 10:51 pm mwccl In my opinion, I think it depends on the value of houses/median around your area. If the median of houses around your area is for example $500k and you build a house worth $1 million, you might find it hard to sell your house later down the road. Double storey would cost a lot more especially in WA since it's double bricks. I am currently building a double storey and everything that has to do with a double storey cost more. For example, the starting price of smart wiring packages for double storey is higher even though you get the same thing as a single storey. Same thing with putting in air conditioning. At the end of the day, everything adds up.... mmm, good point. Re: Opinion: Single or Double 8Aug 19, 2014 11:32 pm We were in the same predicament... In WA After meeting with several 2 story builders we ended up going quality single story with top spec. We still have great views as the front of our block is elevated on the side of a hill. As mentioned above, house prices in the area helped our decision, but in hindsight we got a better quality house with great spec and the views. Good luck on making the tough decision, try to get the best of both worlds if you can. Re: Opinion: Single or Double 9Aug 20, 2014 12:06 pm could also look at going split level and custom. but as you will have views going two story that would be the way i would go especially when looking at the value of a home with views and of one without. Re: Opinion: Single or Double 10Aug 20, 2014 6:25 pm Guess I will do a bit more research on the value and what exact views with each. I am saving up in the meantime for bigger deposit. I will also wait to see what others in the street will do ... if majority goes double.... then I don't think single story will be so value as double .. and vice versa. Re: Opinion: Single or Double 11Sep 08, 2014 4:25 pm 1rocky could also look at going split level and custom. but as you will have views going two story that would be the way i would go especially when looking at the value of a home with views and of one without. So others on the same street as mine (same slope) have gone with a single storey split level house with 4 splits... and their siteworks is about $36000.. Will try find out how much siteworks will be for a double and then compare costs between the two. Re: Opinion: Single or Double 12Sep 08, 2014 5:46 pm We had the same dilemma (also in WA), also a corner block and have ocean views and a fairly big block (for the current market!) at 658sqm so had room for single but we had views, so we've gone entry level 2 storey, sometimes I think about how amazing we could of built a single storey but I love our house plans so next time! We have a mix of single and double on our street, in the area a double will sell for more though, and we have only used 26% of our block so plenty of yard space Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Opinion: Single or Double 13Sep 10, 2014 1:45 pm "I might have glimpse of ocean if i go single, if i go double i will definitely have some ocean view." You've answered your own question right there. Its a no brainer. Oceand views with make your home substantially more valuable, so design a 2 story where there is a deck/entertainement area upstairs to maximise use of the views. Leave the bedrooms on the lower level is necessary. Single level homes are for old folk with hip/knee problems. Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6141 these look like missing batts. Go up and take a look. But yeah moisure meter is a completely different tool 4 9460 Hello All š We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8204 |
