Browse Forums General Discussion 1 Aug 14, 2014 6:45 am Recently I prepared a report on failed inground fibreglass swimming pool The problem with the pool was that soon after construction it heaved around 40 mm at corners + there were workmanship problems with rough sandstone paving, brick water feature was not on the plan and did not have a footing. The cause of heave was plumbing leak that allowed water build up on outside of pool shell and caused swelling of foundation and uplift I argued successfully that the pool was defective in design and construction because it did not have foundation protection in the form of a sump with automatic float pump that would keep excavation dry and prevent catastrophic damage from a build up of water in foundations and because it leaked. I recommended full demolition and reconstruction and provided a cost estimate Builder's insurer commissioned engineering report but it essentially agreed with my recommendations Builder did not put up much of a fight and none of my recommendations and estimates were challenged Owner was awarded full cost of demolition and replacement of heaved fibreglass swimming pool including surrounding sandstone paving. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: VCAT, owner wins damages for heaved pool replacement 2Aug 14, 2014 8:31 am building-expert Builder did not put up much of a fight and none of my recommendations and estimates were challenged Another relieved customer. Why did the "builder" let it be taken to V-CAT and have a judgement against his name if he had no defence? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: VCAT, owner wins damages for heaved pool replacement 3Aug 14, 2014 8:48 am SaveH2O building-expert Builder did not put up much of a fight and none of my recommendations and estimates were challenged Another relieved customer. Why did the "builder" let it be taken to V-CAT and have a judgement against his name if he had no defence? I suspect he needed a judgment to claim on his own construction insurance policy ( hearsay was that he was offered something but wasn't enough) Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: VCAT, owner wins damages for heaved pool replacement 4Aug 14, 2014 5:04 pm Good on you again BE. I so wish you were on our case an tribunal. Please keep fighting for people like us. I agree why let yourself be publicly dragged through the mud...do the right thing, pay up and walk away. I am sure some arrogance or delusion tells them they will win. Good to see times are a changing! Let's hope NCAT follows. It worked for me in getting all non notified rain days removed from the builders claim, although the LDs was only $50/day 7 5861 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7197 |
