Browse Forums General Discussion 1 Aug 08, 2014 1:26 am Just wondering if anyone knows how much it cost to hire a Scissor Lift? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also, does it require a license to operate a Scissor Lift? "Occam's Razor. The simplest explanation is almost always somebody screwed up." Re: Does anyone know how much it cost to hire a Scissor Lift 2Aug 08, 2014 1:58 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Found one that quoted on the website for $187.55 per day, $750.20 per week. http://www.hire-it.com.au/aa-scissor-lift-19-30 "Occam's Razor. The simplest explanation is almost always somebody screwed up." Re: Does anyone know how much it cost to hire a Scissor Lift 3Aug 08, 2014 9:41 am How stable/level must the ground be where you want to work with it ? I'm just not sure that many home builds would have solid and level enough ground to operate one. However, if that was not an issue, it'd be great to have one to use in a build, as you could operate at many different levels that you can't do with plain old scaffolding. Owner Building at Jimboomba Woods in Logan City Qld. ![]() Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Does anyone know how much it cost to hire a Scissor Lift 4Aug 13, 2014 9:39 pm ![]() How stable/level must the ground be where you want to work with it ? I'm just not sure that many home builds would have solid and level enough ground to operate one. However, if that was not an issue, it'd be great to have one to use in a build, as you could operate at many different levels that you can't do with plain old scaffolding. They have stabilizers that level it out - I've seen them on dirt and rubble but nothing too rough Iām not a plumber or builder but it sounds weird. You need an ORG or overflow relief gully 150mm lower than lowest fixture to allow your sewage to overflow outside of… 1 1945 Hi Alex a couple of reasons why we want to pour a slab is that the backyard slopes down towards the house and when it storms underneath the house gets muddy and the water… 6 2978 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 5686 |
