Browse Forums General Discussion 1 May 22, 2015 7:49 pm Hi all, Going to Install some old Cast Iron Lace / Frieze to Terrace house under the balcony see Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The cast iron is pretty heavy, so I'm wondering what kind of screws or bolts would I need to install the 6 pieces? Each piece has 3 or 4 bits to screw up into the wood in the balcony front but the hole is no bigger than 5mm so doubt I could use bolts. As you can tell I'm pretty new to DIY so appreciate any help! Cheers Jimmy Re: Install Cast Iron Lace / Frieze to Terrace house 2May 22, 2015 10:19 pm Cheers mate. The hard thing is finding timber screws with flat button heads and not Bugle or countersunk heads. As thought a flat surface against the metal would be better. Or does that not matter too much? Also would these bad boys be over-kill or the big the better http://www.bunnings.com.au/buildex-14-1 ... k_p2420555 We have a Victorian style ripple iron fence out the front that has some moulded timber capping. Probably 15+ years old and has cracked and splintered in parts...not really… 0 2522 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8804 Hi, I have a block that I am planning on building on soon to both side boundaries, which both have other houses constructed that were also built boundary to… 0 533 |
