Browse Forums General Discussion 1 Aug 03, 2014 10:08 am Our house was built in 2011, in Strathfieldsaye, Central Victoria. Every time we have a frost, which is common here from May to August, our water pipes freeze, both hot and cold. I would have thought new building regulations would require sufficient insulation to prevent this from happening? Re: Frozen water pipes in new home 2Aug 03, 2014 10:34 am Are you on tank water or town water ? If tank water, then it would seem to me that the pipes inside the house are okay, but from the tank to the pump, then to the house need some insulation on them. It town water, then they should be underground all the way to the house, and there's something allowing them to get really cold to freeze up, as being buried usually means they stay at ground temperature, even if you get freezing temps otherwise. Owner Building at Jimboomba Woods in Logan City Qld. ![]() Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Frozen water pipes in new home 3Aug 03, 2014 11:05 am We're on town water. The water is freezing under our house, between the HWS and the faucets. There is no problem with water getting past the meter to our HWS. Our house is on stumps, as are other in our street. However we are the only ones experiencing this problem. Re: Frozen water pipes in new home 4Aug 03, 2014 2:50 pm I dare say the hot is not flowing because there's no cold water to push the hot from the hot water tank. ![]() Is it possible to see what the other houses on stumps in your street are doing with their water pipes ? They may have already learned from experience to insulate their pipes. Not 100% sure on the rules myself, but I dare say insulation of cold water pipes is not compulsory. Owner Building at Jimboomba Woods in Logan City Qld. ![]() Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . It makes sense though. I can’t see any other purpose for the pipes in that location and all the neighbours have covered theirs. But I want to be sure before covering them. 2 3514 DIY, Home Maintenance & Repair I've gone under my house to see if I can find the cause of the high moisture in our home. While crawling around in the damp ground, I came across copper pipes and noticed… 0 2313 that's where your drains should be. the plumber is usually supposed to chop them down to ground level at the end, and cap it with some sort of a grill, like the one you… 1 2056 |
