Browse Forums General Discussion 1 Jul 04, 2014 3:19 pm hi guys i am soon to be removing the old storage tank in the laundry hot water service and having a rinnai infinite installed(by a licensed plumber i am just an apprentice) i am supplying everything and just had a few questions. do i need a tempering valve if the unit is pre set to 60deg and has a remote control temperature setter? and are we able to have the new unit installed out the far side of the house as we don't want it in our yard? the only problem is the bathroom and on-suite will be closer to the unit than the kitchen and laundry. or does it not matter as we have the remote control temp setter? the gas line does not need to be changed as we have also removed an old ducted heating unit thanks Re: Rinnai infinite 60deg questions 4Jul 05, 2014 3:04 pm if you haven't bought the unit yet have a look at the enviro. Have had one running for nearly 3 years now and have saved a bucket load of $$$$$ in gas usage. Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10482 We had this happen to us last year and got charged a variation. Try and give away as much as you can that is usable to charity otherwise if you are in Sydney I have a… 1 4507 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 8255 |
