Browse Forums General Discussion 1 Jun 24, 2014 2:35 pm Hi Guys, We renovated our bathroom and installed this 2 in 1 Square Shower System (shower head and hand shower): http://hbhome.com.au/index.php/product/ ... er-system/ What we noticed is : The water comes out of "shower head" even after couple of hours from turning off the water. Is this normal for this type of shower system? OR we have some sort of plumbing problem here? Anna Re: Problem? Leaking from Shower Head / Rail? 2Jun 24, 2014 3:34 pm We have a square rain shower head too and water will come out hours later too. If you tip it when you get out of the shower it should get rid of most of it so it doesn't drip later Re: Problem? Leaking from Shower Head / Rail? 3Jun 24, 2014 6:32 pm I had the same thing with my square shower head in our last build. It will be interesting to see if the same thing happens with my round shower head this time. Electrical just got back to me and said the most they can provide is a single power point on the Bedroom 1 side of that wall. After handover, your towel rail installer… 2 3816 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17525 |
