Browse Forums General Discussion 1 Jun 20, 2014 2:03 pm Hi All I'm looking at purchasing an acre of land that has reasonable fall from front to back and also some fall from side to side - looking at putting a homestead style house on it. The land is part of a development that hasn't had any works started yet and titles won't be available for a year. My concern is site costs, of course I could get a survey done now (with permission from the developer) but the contour and fill on the block may change as they complete their development works. Would I be better to put a clause in the contract - something along the lines of "Subject to final soil test once site works are completed" and not bother doing the test until it titles? Not sure if they would go for a clause like that? (It was suggested by the surveyor when I inquired about costs) Here's a photo of the lot in question from the rear boundary peg looking to the front Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And an attempted pano from the same spot Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any thoughts on the fall would be appreciated, the last block I purchased was 1/4 the size and had minimal fall, so a bit different! Thanks in advance! Re: Opinions on Land Fall/Survey Please 2Jun 20, 2014 6:16 pm Elli im just taking a stab based on the fence posts on the left, but it doesnt look like theres all that much fall, maybe 1500mm front to back, which is not a great deal over a 4000m block. try to borrow a dumpy level or go and hire one. shoot some levels yourself easy as. Re: Opinions on Land Fall/Survey Please 3Jun 21, 2014 4:34 pm yep what mgilla said, hire a dumpy level and check the fall of the land yourself. I'm a surveyor by trade and the block doesn't look overly steep, depending of the size of your slab you shouldn't be up to too much cut/fill on the block. also are they building a road in that area? The peg you have shown doesn't look like a boundary peg.. look for marks on it, may be indicative of a fill level they are using for construction.. Re: Opinions on Land Fall/Survey Please 5Jun 22, 2014 9:03 pm Thanks for the replies mgilla - I had to look up what a dumpy level was matt68 - There's no road at the rear of the block, it ends at the rear of another acre. I imagine they are just temporary markers for the boundaries so people can see what they are buying - the proper ones are usually just small wood pegs yeah? Handy007 - This is east of Melbourne, there are nice views at the moment but I'm not sure how much I'd see once other houses go up and fencing etc. Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4691 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18402 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 1920 |
