Browse Forums General Discussion Re: Extending Colorbond Fence 5Jun 19, 2014 11:14 am I think they make that for people who just want to increase their privacy. Note the sleeve part of only 5 cms or so, definitely not enough for a 1200mm extension. Its a boundary fence, so you want to do it properly. Bite the bullet and reinstall the posts to the correct height. You could then re use your existing sheeting, and top up as per what i said in my previous post. OR just get new panels made up. Yup, $$$. If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5496 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1685 There is insufficient information to give a meaningful answer. You should talk to council planning. Apart from building construction issues, if you are adding floor area… 1 7978 |
