Browse Forums General Discussion Re: Minimum side setback - in practice is 1.0 m enough? 6Jun 14, 2014 10:07 pm Build thread: viewtopic.php?f=31&t=65085 Re: Minimum side setback - in practice is 1.0 m enough? 7Jun 14, 2014 10:08 pm Build thread: viewtopic.php?f=31&t=65085 Re: Minimum side setback - in practice is 1.0 m enough? 8Jun 14, 2014 10:10 pm Build thread: viewtopic.php?f=31&t=65085 Re: Minimum side setback - in practice is 1.0 m enough? 11Jun 16, 2014 6:42 pm Build thread: viewtopic.php?f=31&t=65085 Re: Minimum side setback - in practice is 1.0 m enough? 13Jun 21, 2014 8:32 pm If you worry so much about access to the back, I suggest having a rear garage door as well. Makes it that much easier. Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15705 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6868 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3650 |
