Browse Forums General Discussion 1 May 30, 2014 10:44 pm This media release will be welcomed by many. http://www.abcb.gov.au/~/media/Files/Do ... EFORMS.pdf "The forum agreed in principle to make the 2015 National Construction Code (NCC) and future editions freely available and online, with details to be finalised in the coming months." 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: National Construction Code - Media Release 30/05/2014 2May 31, 2014 8:56 am Making the NCC freely available is a very welcome step. I'll be interested to see what other reforms they are intending to ensure the NCC is "robust, without strangling the sector with red tape"???? Hopefully not watering it down. Re: National Construction Code - Media Release 30/05/2014 4May 31, 2014 9:49 am "Mr Baldwin said other reforms were eliminating the NCC’s purchase price (almost $400), improving small business’ access to the NCC , and increasing the number of building and plumbing practitioners able to access using the NCC from 12,000 to around 200,000 across Australia." Is the above an admittance that 188,000 out of 200,000 building and plumbing practitioners currently don't access the NCC? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: National Construction Code - Media Release 30/05/2014 5May 31, 2014 11:06 am Yeah, that says a lot doesn't it. About time too. Now it means if this goes through that there will be no excuse for anyone involved in the building industry from designers through to tradesmen not to know the rules. It also means clients will be more familiar with what is required as well. Thanks for the link SaveH2O. Stewie Re: National Construction Code - Media Release 30/05/2014 6May 31, 2014 1:36 pm ITs a disgrace that it hasnt been freely available for so long. The amount of empowerment it will give to owner builders and others will be fantastic, and help to keep the bastards honest. (to use Don Chipp's phraseology) Re: National Construction Code - Media Release 30/05/2014 7Jun 05, 2014 8:18 am I was talking to a builder friend a couple of days ago and he also heard that updates will be every two years or so not incremental as they occur. Stewie Re: National Construction Code - Media Release 30/05/2014 10Jun 05, 2014 8:54 pm Quote: Can you explain what doesn't work? I only have the 2012 version. Stewie The on-line 2014 version only displays the text correctly. There is a "X" where the tables & figures should be. I have check this using another work mates computer and the same happens for them when they try to view the 2014 NCC on line. Unfortunately Tables are figures are often the very thing you want to view as they usually contain really useful information. I have access to a hard copy of the NCC so it is not an issue for me. This also happened about 10 years ago with Australian Standards when they were first available on-line. Standards Australia have long since fixed this problem for their subscribers. Re: National Construction Code - Media Release 30/05/2014 12Jun 06, 2014 9:37 am Quote: Ah, my copy is a pdf so I was wondering why the problem. That explains it. Cheers, Stewie Stewie, I did a bit more research and found that the On-Line version does not work with Microsoft Internet Explorer. It only works with Opera, Safari and Firefox. Re: National Construction Code - Media Release 30/05/2014 13Jun 06, 2014 11:37 am Good old Micro$oft! Lucky I use a Mac and Safari/Firefox. I've been to a few forums and websites that say not to use IE as there are compatibility issues. Add another to the list. Stewie Re: National Construction Code - Media Release 30/05/2014 14Jun 06, 2014 11:57 am Stewie D I was talking to a builder friend a couple of days ago and he also heard that updates will be every two years or so not incremental as they occur.Stewie The high cost and the need to annually update no doubt have been a primary reason why many industry persons have fallen out of kilter. Biannual updates may appear to be a retrogressive trade off but it is a change that most probably will also prove popular. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: National Construction Code - Media Release 30/05/2014 15Jul 18, 2014 2:34 pm Beetaloo Quote: Ah, my copy is a pdf so I was wondering why the problem. That explains it. Cheers, Stewie Stewie, I did a bit more research and found that the On-Line version does not work with Microsoft Internet Explorer. It only works with Opera, Safari and Firefox. Stop using your browserplugins. Download the pdf, then read it with Adobe acrobat. It should work. Re: National Construction Code - Media Release 30/05/2014 16Sep 11, 2014 1:17 am The NCC will be updated every three years once it becomes available online in 2015. http://www.abcb.gov.au/about-the-nation ... y%20Reform 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8432 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16537 |
