Browse Forums General Discussion 1 May 19, 2014 9:55 am Hello Guys, We have one of those water efficient toilets in our just renovated bathroom– and I just find there isn't enough water when flushing. The tradie has installed this one : JohnsonSuisse Plaza Plus Vitreous China cistern and toilet seat 4.5 litre per full flush 3 litre per half flush 3.4 litre avg flush like this : http://www.gemini-industries.net/inv_ds ... cordid=158 Here is the water level in cistern : http://imgur.com/EM58pAl Total height : 31cm Water Filled till : 17.5cm Not sure of this water level is correct? OR some other problem causing not enough water when flushing. What do you think? Thanks Re: Efficient toilets - not enough water problem :( 2May 19, 2014 10:01 am Hi It looks like cistern float is set too low (it regulates how much water is stored) however it is adjustable and if you are handy you can do it or call the plumber and get him to fix it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Efficient toilets - not enough water problem :( 3May 19, 2014 10:49 am building-expert Hi It looks like cistern float is set too low (it regulates how much water is stored) however it is adjustable and if you are handy you can do it or call the plumber and get him to fix it. Thanks for your quick response What is the recommended level for cistern float? Re: Efficient toilets - not enough water problem :( 4May 19, 2014 11:26 am building-expert Hi It looks like cistern float is set too low (it regulates how much water is stored) however it is adjustable and if you are handy you can do it or call the plumber and get him to fix it. Agree. The overflow looks low too but that might be an optical illusion. Adjusting the float valve is easy but I assume that a plumber installed this. That then begs the question; Why didn't the plumber test it after installing it? It would have taken less than a minute. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Efficient toilets - not enough water problem :( 5May 19, 2014 11:57 am thehuntbegins building-expert Hi It looks like cistern float is set too low (it regulates how much water is stored) however it is adjustable and if you are handy you can do it or call the plumber and get him to fix it. Thanks for your quick response What is the recommended level for cistern float? If you look inside cistern walls there should be marking indicating fill level. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Efficient toilets - not enough water problem :( 6May 19, 2014 1:30 pm Ive installed one of those Suites. they are a good toilet and work well. So its definitely the water level. Anyone can easily set the float level (its the device on the right of your photo).
As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 573 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 10354 Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5382 |
