Browse Forums General Discussion Re: Bricks, cladding, sheeting, foam are these all real opti 5May 19, 2014 10:43 pm People make one happy, not houses? I do not think so. Houses are more to be trusted than people. Elizabeth Aston, Mr. Darcy's Daughters http://www.youtube.com/watch?v=pmDX0tgONFs http://lightndreamy.blogspot.com/ Re: Bricks, cladding, sheeting, foam are these all real opti 8May 20, 2014 8:10 am Possibly St M. but more like misinformation and a lack of acceptance of newer ( OK I know poly has ben around as cladding for 30-40 years ) building materials by everybody from builders to clients. Stewie Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5369 Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 11958 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4108 |
