Browse Forums General Discussion Re: How deep do I own my land? 2Apr 24, 2014 1:21 pm I had a similar question but no one was able to give me an "Xmetres" answer. The responses I kept on getting was anything above or below the surface needs Gov't approval (be it local, state or fed). So they can tunnel or mine beneath you, planes can fly over etc. You may be given the opportunity to object and maybe even put forward an alternative but the benefit can be given to someone other than the owner without having to compensate them unless it actually affects your building (as in damages it) or they need to acquire your property. Am I touching on what you're problem may be or are you being affected by say an easement? Either way I wouldn't say my response is complete, I'd like to think things are a little fairer than what I've put forward. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: How deep do I own my land? 3Apr 24, 2014 8:45 pm Thanks for the post, I don't have a particular problem, it's just a hypothetical question that no-one seems to have a concrete answer for. From what you're saying there's no limit, except you need council approval.. But how deep until you need council approval? Re: How deep do I own my land? 4Apr 25, 2014 11:10 am Hi, I think it is 30 metres based on the Mining Act 1978. You can have the rocks and dirt but the ownership of any worthwhile minerals or petroleum in or under your land is always reserved to the Crown in Aust. If you don't agree to mining it, they can only mine below 30 metres. The local Council can regulate what you do on your land and above it, and usually does so, but generally has no ownership itself. Cheers Re: How deep do I own my land? 6Apr 27, 2014 7:44 am Contract just passes land from one person to another and normally prepared by the vendor, I wouldn't be trusting anything on there. I would imagine if it were anywhere it would be on your title but NSW at least does not list it. http://camdenbuild.blogspot.com.au/ by invite only please pm me Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20426 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6445 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24872 |
