Browse Forums General Discussion Re: Current cost of double brick inc. materials and labour 2Apr 24, 2014 2:31 pm That depends where you are - NSW, WA, Texas?? It also depends on which brick you are using - some are worth a lot more per 1000 than others ( face bricks ) or whether you are going to render the outside in which case you'd use commons for both. It also depends whether you are using metric or modular bricks. You have to give us a bit of info first. Stewie Re: Current cost of double brick inc. materials and labour 3Apr 24, 2014 2:45 pm Stewie D That depends where you are - NSW, WA, Texas?? It also depends on which brick you are using - some are worth a lot more per 1000 than others ( face bricks ) or whether you are going to render the outside in which case you'd use commons for both. It also depends whether you are using metric or modular bricks. You have to give us a bit of info first. Stewie I guess I was after general numbers that people had for their location. I am specifically after double brick walls in Perth. Using the most economical brick, probably the plain common modular brick for render. Re: Current cost of double brick inc. materials and labour 4Apr 25, 2014 9:30 am Working it out per sq m isn't the best way of doing it. Work out how many bricks you will need for the whole job then allow somewhere around $1.20 per mod. brick to lay ( last time I looked ) . All your other costs like sand/cement, lintels flashing etc are extras. Here is a good guide even though it is for metric bricks and blocks... http://www.bricklayaustralia.com.au/ima ... 2-2013.pdf Stewie Hi Everyone, wondering if anyone has done a prestart lately with summit homes in WA and what kind of costs were associated with adding gpo's and downlights? we are also… 0 3862 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17526 |
