Browse Forums General Discussion 1 Apr 15, 2014 7:56 pm Hi all, according to the plans for the subdivision we are purchasing a lot from, we will have a 2.5m easement at the back of our property. Just wondering what council requirements are for applying to build a shed over the easement? Is it a requirement to encase/enbumbus the pipes before we gain approval to build or is this not necessary if it's acknowledged that is at our cost if council ever needs to access easements in our lot. I am in NSW. This is all pretty confusing. Please help!!!! Re: Building a shed over sewer/storm water easement 2Apr 16, 2014 9:26 am Enbumbus ? That's a term I am unfamiliar with. Bear with me as I am only a humble carpenter by trade so enlighten me. Is it a sewer easement, stormwater or both? Sewer only and the council doesn't have any say - it is Sydney Waters domain and they have strict guidelines as per their website. Sydney Water will let you build over their mains sewer but will make you concrete encase it and at $1100 per lineal meter makes it reasonably expensive. You have to submit plans for that pre-DA. If it is stormwater then that depends on your particular council and what their requirements are. A quick chat with a planning officer would be able to tell you. See this thread here re sewer ... viewtopic.php?f=1&t=69324&p=1129658&hilit=concrete+encase+sewer#p1129658 Stewie Re: Building a shed over sewer/storm water easement 3Apr 16, 2014 12:18 pm It really depends on what sort of shed you plan building. Many councils, and Sydney Water, will let you build a small (less than 10m2) lightweight (timber or colorbond on simple slab) shed over an easement with just a letter of indemnity. The less 'removable' the structure the stricter the requirements. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Building a shed over sewer/storm water easement 5Apr 16, 2014 2:21 pm In Qld, and I think nationwide, the rule is that a structure up to 10m2 in area and not more than a certain height (forgot it) , does not need a building permit. Thus you could just build it without an indemnity anyway. But of course if it impedes stormwater flows, or impedes maintenance in the easement area, you can be told to remove it also by the easement owner.. I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to… 3 3210 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7790 |
