Browse Forums General Discussion 1 Oct 05, 2006 11:04 am I was wandering if anyone had any experiences to share re. solar hot water - any recommendations, do's and dont's, I'm having some trouble getting reliable information re. position (angle) of solar panels for Melbourne, etc.
Also, has anybody got anything to say re. heat pump to heat water, more info here: http://www.supremeheating.com.au/siddon ... t-pump.htm Thanks! Solar 3Nov 07, 2006 9:28 pm Hi everyone
For this kind of info, I really recommend: (1) Joining the Alternative Technology Association (www.ata.org.au). It's $65 for an individual membership and that entitles you to free, unbiased, not-for-profit advice as well as discounts with many retailers. Their staff have a phenomenal range of knowledge about all things solar, as well as water conservation, insulation, windows, chook palaces and many other important matters! (2) Subscribing to Ecospecifier (www.ecospecifier.org), a database that once again gives you unbiased assessments of a huge range of products from an ecological viewpoint. Cheers Elizabeth the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24149 |
