Browse Forums General Discussion Re: Instant hot water not holding temp - told it's normal?? 9Mar 25, 2014 8:47 am we have one and it does what your experiencing if the flow is too slow. The way we operate it is set the temp to 44ish and pretty much use 'full hot' (I use a little bit of cold as what suits the wife is a bit hot for me). The kids have their bathrroms controller set to 40 and they use full hot (most of our taps are flickmixers). When filling the kitchen sink for dishes, we up the controller to 55 and use that. We find it works really well. Only think I have an issue with is I do B&W photos in my darkroom, and I can't get the tap to run at a low enough temp (20C) for washing film (I use another method that actually saves water anyway) the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14048 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
