Browse Forums General Discussion Re: Linking 2 water tanks, why doesn't this work? 8Mar 11, 2014 5:18 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 12Mar 14, 2014 1:10 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 14Mar 15, 2014 1:59 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 15Mar 15, 2014 11:16 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 17Mar 19, 2014 6:35 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 19Mar 20, 2014 5:46 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Linking 2 water tanks, why doesn't this work? 20Mar 21, 2014 10:58 am Is the smaller tank's outlet valve that supplies the pump(s) a 32 mm valve or do you have a 32 mm (27 mm ID) poly pipe connected to a 1" or even a 3/4" outlet valve? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 14117 6 7972 |
