Browse Forums General Discussion 1 Mar 03, 2014 4:28 pm Hi all, I have been trying to get an answer out of a few builders regarding the approximate price difference between rendered hebel and unrendered brick on a 24 square new home, I know hebel goes up a lot quicker then brick but being that the hebel needs to be rendered and painted with a few coats of paint I would have thought that brick would work out about the same price as I would leave the brick bare (unrendered), so has anyone done the research before on a previous build? Re: Rendered Hebel vs Unrendered Brick Approx Price Differen 2Mar 04, 2014 8:36 am What is your total wall area? Is it only external or internal too? Re: Rendered Hebel vs Unrendered Brick Approx Price Differen 3Mar 04, 2014 4:36 pm hi there, not sure about the total wall area all up but the house is 20.6m long and 12.3m wide and is approx 24 square (single story). The hebel would be external only. I finally got some info from some builders today and it depends who you ask as a lot of the bigger building company's charge more for hebel and some smaller company's are charging less so I guess it depends who you go with. Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8486 This is 100% true. You can not hang anything on steel frames. very frustrating 8 5217 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11103 |
