Browse Forums General Discussion 1 Mar 02, 2014 4:07 pm We have a block which has a slight slope on it going across the block (eg as you look at it, the left side is about 60cm higher than the right side). Some pics are here http://i.imgur.com/oYaZPBs.jpg http://i.imgur.com/bkew3ya.jpg The back 20 meters or will be the backyard. As you can see there is a slight slope (look at the back fence line). We will have some soil left over from the earthworks - just wondering what peoples thoughts are about using some of the soil to level out the back section of the yard? Or just keep it with a slight slope? Re: Earthworks - to level or not to level the block? 2Mar 03, 2014 7:51 am It will depend a lot on whether you intend to have formally landscaped backyard with lush plants, waterfalls etc and minimal lawn. Stepped landscaping can look very nice with small rock walls and ground cover plants tumbling over them etc but level it if you have kids and intend to have it as mostly turf. A level lawn is so much better for kids to play on. If you do decide to level it you will need to build a retaining wall on the existing lower side. Stewie isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17817 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6748 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47157 |
