Savings - Electricity ?
Page 2 of 2
Just get an extra circuit on that side, and chances are is that your sparky will only need to put in another circuit breaker, and swap the cable across to it.
In Qld, you can put anything on to off peak provided that it is hardwired in, but there was one exception that you could have a pool pump remain as a plug in device on off peak.
Its why I'm looking at the 18 hours one - not the overnight only.
Switching over whatever you can to off peak is a good idea though as well.
Stewie
All ideas, tips and help welcomed ...
I would be looking at the current pump and comparing it to the cost savings when using a variable speed drive pump. You might still be eligible for a rebate, it would pay to check now.
Using a pool blanket also cuts down on the required pump run time.
There are many simple ways to reduce power consumption in other areas. Filling a jug with only the required amount of water and not filling it when making a cuppa saves time as well as energy.
Using cold instead of hot water in the laundry also saves a lot of energy.
Using a solar clothes dryer (they don't cost much) instead of a tumble dryer saves lots of energy AND eliminates a potential fire risk (built up lint).
Deciding first what TV programs to watch rather than sitting down and turning the TV on saves time and energy consumption.
If you have a dark living area that needs the lights on, consider installing a sky light.
Don't use stand by power. There is no need to leave microwave ovens and a host of other electrical items on when not in use.
When you buy new electrical items, check their electrical consumption.
If you have a water bed, throw a good blanket over it when not in use.
- I have one that I can alter the revs on - is this what you mean. It starts higher for 5 minutes then can drop down to a speed I set.
-Tell my wife this ...
- Do this - good idea.
- Do this.
- Is this the sun ?
- I know - but I'm a surfer ...
- Have this.
- But, hard to turn off - when socket is at rear.
- Good idea.
- Don't have one.
That's the type.
HaHa! No thanks!
- Is this the sun ?
Yep.
Aaah! Real bad habit and hard to get out of. Suppose we are all allowed some vices.
- Good idea.
- Good idea.
Many new devices also use little stand by power but the information can be hard to find. ReNew magazine, published by the Alternative Technology Association, is a good read and has a lot of information about energy efficient products etc. Going by your obvious attention to detail, I am confident that you are aware of the magazine.
The Japanese engineer calling for a life without electricity
http://www.theguardian.com/environment/ ... lectricity
And he even has a poem on his website:
Human bore electricity
Electricity bore convenience
Convenience bore obesity
....Then....I'll reduce electricity
Human increased electricity
Electricity increased CO2
CO2 increased troubles
.....Then...I'll reduce electricity
But.....
Reducing electricity reduces convenience
Reducing convenience reduces time
Reducing time reduces money
Reducing money reduces happiness
....Is it true ?
His website: http://www.hidenka.net/etop.htm
All shamelessly lifted from the ATA Forum
I got off-peak on - finished - yesterday. Will watch and report back.
With my solar HW and E and off-peak for all of the pool stuff - heater and pump - I hope it will mean less outlay ... and CO2 ... Hai !!!
our bills range from 200 winter/ 380 summer
We have 2.0kw solar , 3 phase refrigerated AC which gets a big workout over summer and an inground pool and Spa. TOU with all this stuff is the key to saving money. Located in Melbourne
i got email from EA and they are putting up prices again in jan over the 28c per kw general tariff.
mixo
Hi all, the offpeak rate seems high i just signed up with new supplier 9.97c offpeak 20.3 peak plus gst.
Hahaha. Come to regional NSW. Peak about 33c/kWh, offpeak 13, and the real kick in the guts, the daily supply charge is $1.40
TOU is 36 peak, 14 offpeak and still 36 for the shoulder period.
Add a lousy 8cfeed in tarrif with solar and were being well and truly screwed compared to your rates.
here i even pay higher petrol prices especially holiday times.
have a 5kw twenty panel solar system .
was advised to set up all the pool pump etc for mid morning (around 10am)
this seems to work ok. electricity bill is around 250 per quarter.
will be interested to see bill with all the hot weather here and see how it goes.
that sound real cheap to me, who is the supplier?
mixo
mixo
Simply energy, i was surprised i can get another 2% off if i direct debit as well. i was with momentum energy who were a hydro supplier from Tassie had good supply charge 70c day with great rates as no carbon tax,they just couldnt match simplys rates.
hope this helps
mixo
mixo
hope this helps
Oh lordy. Simply energy have probably the most atrocious reviews of any retailer, I hope you don't have the same issues as other people have had.
Simply energy also don't have any plans for customers with solar so aren't even an option for me.
mixo
mixo
hope this helps
Its not that hard i can veiw all my usage online through Jemena website and compare to bill and yes they do have a solar tariff as i am on it its a T10 TOU. all avail in Melbourne.
