Browse Forums General Discussion 1 Feb 08, 2014 6:20 pm After struggling for a day I used the next day to think of an easy way to refit the screens. I got a decent piece of strong string and tied it around the screen from side to side 6" from the top, secured it with a reef knot on the inside. I then put the screen outside (I personally removed the sliding window as its easier.) I offered up the screen so that it was just below the top frame and equal overlap at each side, Then hold the bottom tab with one hand pull the top of screen into its place , move down a 6" or so and keep pulling into place then pull up the tab to place the screen into the top, pull remainder of screen into place if not already so and pull down screen into its place at the bottom...Undo the reef knot and gently pull out the string...(I used a lace from a running shoe) prior to starting I brushed a small amount of washing up liquid onto the frame to make the screen slip into place easily. 2 screens done in 5 minutes. Regards fabphil72 Re: Easy way to refit alum. flyscreens. 3Feb 09, 2014 7:58 am Not sure we are talking about the same thing - but when replacing a screen I have a little roller gadget - like a pizza cutter - but its rubber - and this forces the screen into the side mould. Works well. Re: Easy way to refit alum. flyscreens. 4Feb 15, 2014 4:47 am No not talking about the same thing you are talking about making a screen I am talking about taking an existing screen out of an aluminium frame and how to refit it.... perhaps I was a bit ambiguous Re: Easy way to refit alum. flyscreens. 5Apr 05, 2014 1:06 am Usually slide the top and left edges in first. Once those parts are in the grooves then hit or nudge the screen upwards into the top cavity. Then you can push it in flush and pull it down into bottom cavity and slide it into right cavity. Make sense? I do it all the time on ours tame home when it's cleaning time. DIY, Home Maintenance & Repair I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for… 3 41577 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4559 4 9088 |
