Which roof is best? Colorbond v. Tile
Page 1 of 3
Surely I was wrong - otherwise why are there so many new homes with it now? So I am asking - what is really better? Am looking for the solution which provides the best insulation (for both noise and heat etc), longest lasting, low maintenance etc. for every thing I find as a pro con, I can find a contradicting article
Please help!!!
Colourbond can also be noisy during heavy rainstorms or hail, however you won't break colourbond like you can break tiles.
Tiles also never completely seal.
Rain and hail noise on colourbond can be overcome by adding insulation in the roofspace, and some even having insulation batts immediately under the colourbond and on the roof trusses.
What am I having on my new home? Colourbond in Surfmist colour.
I love the sound of rain on a colourbond roof !
We have offered colourbond for free as an upgrade and debating +'es and -'es.
It is normally a $7K option. here in sydney.
Anybody choosing colourbond give some reasons, My builder includes sarking underneath.
Only concerns is weight of solar panels if I add them later vs concrete tiles would have more support.
Also solar panels on a tiled roof needs to be done properly lest you get water leaks courtesy of a poor installer.
I've written more on the differences at this link: http://www.anewhouse.com.au/2012/02/whats-on-the-roof/
Me too ! getting Surfmist also !
Me too! The sound of rain on the roof is the number 1 selling point.
well, maybe not the number 1, maybe the one I enjoy the most anyway, the main selling point is that the roof will cool down almost as soon as the sun goes down. I'm sick of living in old houses with poor insulation that get hotter at night when the sun goes down and the double brick and tiled roof release all the heat theive captured during the day.
I've also heard too many stories of people having broken tiles and leaks, especially after a huge hailstorm, which isn't likely to
happen with Colourbond, the worst you'd get is a bit of a dent in it.
Basically I think Colourbond is far superior to tiles. In general I think they look better too, however a really nice high end tile can look absolutely fantastic, but when there was no difference in price the colourbond was a no brainer compared to the ugly category 1 tiles on offer.
We've got a Classic Cream roof, Surfmist is just too bright for our liking.
I've built new with both colorbond and tiles. If I was to build for a 3rd time I would go colorbond.
Read that one, but I think you might like to add to it Zincalume is not allowed in many estate convenants, such as the one I'm in. Also zincalume goes 'off', i.e. it dulls right down over several years and becomes significantly hotter than light coloured, colourbond roofs.
A older zincalume roof that has dulled down is actually extremely hot. On my old house there was a small section that missed out on being painted, as it was at the painting stage covered by a solar panels, which was later moved leaving the unpainted section exposed to the sun. On some days you could not leave your hand on it lest it got burnt, however less than a metre away was painted in the colourbond colour of Thredbo White, where you could sit down on it to have a picnic lunch as it was still cool.
Since all reports that colourbond is the same price as zincalume, you're better off getting colourbond.
Sadly some builders have got contractual arrangements to build all their houses with tiled roofs, they charge significantly more for a colourbond roof, when it should really be cheaper to go with a 'tin' roof.
Well you certainly would not have wanted to get it in Thredbo White then... makes Surfmist look like Classic Cream.
coolmax-whitehaven,which they claim has a
9% higher solar reflectance than surfmist.
People obviously want a dark coloured roof. In our estate I'd say maybe only 1 in 10 houses has colourbond and only 1 in 20 has a light coloured roof. I wonder how much energy is saved on cooling in summer. Colourbond vs Tile, light vs dark, etc.
The key to keep your house call is to keep direct sun off the walls and windows.
Forgot to mention I have a 1 kwatt solar power system.
That would be interesting information, I like the darker tones/colours but if the savings are significant I could be convinced to compromise.
Someone in a thread on here somewhere did quite a bit of research into light vs dark colours on a roof with loads of supporting evidence and the truth of the matter was that it makes bugger all difference in terms of heat gain.
As for tiles versus colorbond and heat gain, colorbond transmits heat faster but doesn't retain heat and loses heat faster than tiles. So in summer heat may build up faster than a tiled roof but will cool down faster in the evening as it doesn't retain heat. In winter the heat retention of tiles can be a plus.
Which is better? Really it depends on what you like the look of most. Each has its advantages and disadvantages. A leak in a colorbond roof can be harder to trace and repair than a tiled. Cement tiles will break more easily than than terracotta ones. A colorbond roof is more resilient to hail but can just as easily be damaged in windy storms. You may find rain noise annoying on a colorbond roof, however conversely it may be a sound you enjoy. A tiled roof may require more maintenance.
I'd use either depending on how it looked with my house.
viewtopic.php?f=20&t=65485
I was worried about the colour of my colorbond roof, and yes the summary is only very minor difference.
in theory metal conducts more..
if a tile breaks it's far easier to replace, try replacing a single sheet of colourbond, in theory if you get a dent in the colourbond it won't necessarily create a hole but that dent will NEVER come out, I've found that when walking around on colourbond it's VERY easy to dent and then it's that replacement pita.
I've noticed that plenty of old Colourbond installs have the paint eventually turn into a powder and fade, never seen that with tiles (but then I've never looked that closely)
Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to…
17/08/2023
1
Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust…
9/04/2024
4
You should pressure clean your roof first and make sure the paint you buy also is anti mould.
