Browse Forums General Discussion 1 Jan 27, 2014 10:38 pm Hi we lived in our shed for three years prior to building. We are now wanting to convert the shed accommodation to a double garage. The accommodation area is stud frame and gyprock inside a wide span shed. We need to remove a load bearing wall that separated the lounge area from the bedroom to fit the cars in. Would like to keep the gyprock ceiling and perimeter walls. Who would we contact to do this type of job? The accommodation was already constructed before we purchased the block. Thanks Re: Shed conversion 2Feb 01, 2014 10:30 am Walls are not always necessarily completly load bearing, maybe theres a column in the wall that is the only load bearing component. If you are altering the load bearing componet of the wall you will need a licenced builder/engineer else any contractor or you could do it. -mick Quote: I Have Done So Much With So Little For So Long, I Can Do Almost Anything With Nothing Now. DWB Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold… 2 3538 From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 7832 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11286 |
