Browse Forums General Discussion Re: Building Inspector - Ask Anything 181Nov 23, 2015 8:15 pm Sorry Daz_ my bad I should have explained myself better for others item No (2) the height of the last fixture on the low end, so it could be a floor waste, sink, shower waste etc BTW it sounds like you have a flat slab on a relatively flat ground.. unfortunately it makes you case worse hob or BF valve I would say you gully is set high relative? https://www.google.com.au/search?q=outs ... sp9NdDM%3A Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building Inspector - Ask Anything 182Nov 23, 2015 8:33 pm Oh I see, in that case I believe the ensuite toilet will be the lowest fixture for the property. I dont have the drainage plans so I'm not sure what height the gully will be set at but it is a completely flat block so it will be high. My build with FHBD viewtopic.php?f=31&t=78344 Re: Building Inspector - Ask Anything 183Nov 23, 2015 8:49 pm Thanks for the plans The lowest waste fixture would be the shower unless the bath is recessed into the slab if you follow me. The built up hob contains any back flow within the shower basin. The builder doesn't provide the plumbing/sewer plans (just the fitting locations), the plumber submits them to the water authority these show pipe locations & depth ,inspection holes, gully locations etc. You should definitely get a copy/record for yourself.HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building Inspector - Ask Anything 184Nov 23, 2015 8:59 pm Thanks for the info BIMGuy My build with FHBD viewtopic.php?f=31&t=78344 Re: Building Inspector - Ask Anything 185Nov 24, 2015 11:43 am Refer to image at the top of the page 9- I would like to know your professional thoughts on a supporting roof beam that is strutting off a hanging beam. Builder says its not an issue/supporting beam and can be removed. They have since gyprocked over it. another question - is it typical from a builder to deviate from the plans the client/customer signed off on without notification? I refer specifically to bulkheads - they were meant to be raking, and were changed to square, and one room has a change to one bulkhead where it is about 1m wider than on the plans to cover a drafting error in the roof. My Build: viewtopic.php?f=31&t=74866 Re: Building Inspector - Ask Anything 186Nov 24, 2015 1:01 pm Excited_much Refer to image at the top of the page 9- I would like to know your professional thoughts on a supporting roof beam that is strutting off a hanging beam. Builder says its not an issue/supporting beam and can be removed. They have since gyprocked over it. Its hard to give a definitive answer from the photo, considering its a metal roof its probably OK..Besides its now covered up too late for site inspection now? Excited_much another question - is it typical from a builder to deviate from the plans the client/customer signed off on without notification? The Builder can deviate in regards to minor construction or structural matters if advised to by an Engineer. He doesn't need to notify you...although out of courtesy I always explain the option to clients Excited_much I refer specifically to bulkheads - they were meant to be raking, and were changed to square, and one room has a change to one bulkhead where it is about 1m wider than on the plans to cover a drafting error in the roof. Granted people makes mistakes (and I deal with them all the time on site) and I am Sorry there isn't enough information for me to accurately comment Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Building Inspector - Ask Anything 187Nov 26, 2015 4:47 pm Hi All, My builder advised if he obtains Basix cert Read as Client to Install AC post handover, they are saying I may not get interim occupancy certificate, until I install AC. Is that right Re: Building Inspector - Ask Anything 189Dec 03, 2015 11:42 am I hope you mean particleboard, not plasterboard. Plasterboard needs to be supported on all sides including the front Re: Building Inspector - Ask Anything 190Dec 03, 2015 11:45 am I have a question Building Inspector. By Building Inspector do you mean Building Consultant? Because they are not one and the same in Victoria at least. Re: Building Inspector - Ask Anything 191Dec 03, 2015 11:47 am I have another question Building Inspector. Do you have a definition of DEFECT... because that is what one is looking for in new work. Consumer Affairs Victoria has a definition, but it does not spell out what the implied warranties of a builder actually are. Re: Building Inspector - Ask Anything 192Dec 03, 2015 7:13 pm Leonardo_23 I have another question Building Inspector. Do you have a definition of DEFECT... because that is what one is looking for in new work. Consumer Affairs Victoria has a definition, but it does not spell out what the implied warranties of a builder actually are. Firstly you are looking in the wrong place and not asking the right person. Here is the answer: 1 Building defect is defined by law. 2 The relevant law is Domestic building Contracts Act 1995 3 Definition: "defective, in relation to domestic building work, includes— (a) a breach of any warranty listed in section 8; (b) a failure to maintain a standard or quality of building work specified in the contract;" In addition, there is protection of Division6 in relation to display home: "The builder must construct the home using the same plans and specifications and to at least the same standards of work quality and quality of materials as were used for the construction of the display home." I hope that cleared it up for you. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building Inspector - Ask Anything 193Dec 23, 2015 11:00 pm Not exactly, because the Domestic Building Contracts Act 1995 actually implies more than that. Defective work as to implied warranties means more than that... those listed do not include all of them. For instance... systems and materials when installed must be able to last a reasonable amount of time, not just 6.5 years. This brings up the topic of inferior alternative solutions as well. It is not all covered by law as to the spelling out of these matters in detail. What's more Contracts based on the Act just mentioned do not define specification adequately. There are precedents on the basis of reasonable life expectancy in VCAT and the Supreme Court. That is not stated in Section 8. And why is the very definition of what building consultants are looking for ... namely DEFECTS not relevant to this post perhaps more than any other??? Re: Building Inspector - Ask Anything 194Dec 24, 2015 8:18 am If the builder/subcontractor substitutes Building materials and they are found to be not "fit for purpose" over time then the homes owner has major problems. A building inspector and Building Act wont be able to help you. Please consult an engineer and lawyer. I see homes being built that will be problematic to fix in years to come Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building Inspector - Ask Anything 195Dec 25, 2015 7:04 pm Is there building regs/codes that apply for using able flex type products on slabs and pathways etc. if so that anyone have a link or similar they can point me in. As we have just had driveway and pathway put in and they used able flex on the bricks and downpipes but around the slab we have a concrete visible termite barrier strip and there isn't any able flex on it and the builder reckons it can void warranty because it isn't there Re: Building Inspector - Ask Anything 196Dec 26, 2015 10:48 am Leonardo_23 Not exactly, because the Domestic Building Contracts Act 1995 actually implies more than that. Defective work as to implied warranties means more than that... those listed do not include all of them. For instance... systems and materials when installed must be able to last a reasonable amount of time, not just 6.5 years. This brings up the topic of inferior alternative solutions as well. It is not all covered by law as to the spelling out of these matters in detail. What's more Contracts based on the Act just mentioned do not define specification adequately. There are precedents on the basis of reasonable life expectancy in VCAT and the Supreme Court. That is not stated in Section 8. And why is the very definition of what building consultants are looking for ... namely DEFECTS not relevant to this post perhaps more than any other??? I am not sure what yhou are trying to say, can you explain better wat you mean by 6.5 years in relation to defects and the relevance of alternative solutions in relation to defects? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Building Inspector - Ask Anything 197Dec 30, 2015 12:26 pm Sorry if this is been answered !! Im building new home brought building inspector for 5 stages but SS wasn't happy about it. Obviously I expect good relation with him for the journey. How do we convince him ? What if SS doesn't agree to fix the issues reported ! Re: Building Inspector - Ask Anything 198Dec 30, 2015 12:49 pm janidbest Sorry if this is been answered !! Im building new home brought building inspector for 5 stages but SS wasn't happy about it. Obviously I expect good relation with him for the journey. How do we convince him ? What if SS doesn't agree to fix the issues reported ! Talk to your SS. Tell him it's in his best interest of quality. Will mean that at least if something is found and fixed that it doesn't reflect badly on him but that he's done a good job. Re: Building Inspector - Ask Anything 199Dec 30, 2015 1:27 pm janidbest Im building new home brought building inspector for 5 stages but SS wasn't happy about it. Obviously I expect good relation with him for the journey. How do we convince him ? I would be much more concerned about the SS having little confidence in his own ability as well as his non acceptance of the new home owner's legal rights. Just how far will this lack of professionalism extend? I wouldn't want someone like that supervising my build...too many similar stories in these threads. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building Inspector - Ask Anything 200Dec 30, 2015 7:32 pm This is not about SS at all and is all about your private inspector guiding you and assisting you in your dealings with your builder. Why isn't he? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I would send it to the certifier who is technically your representative and working on your behalf not the builder's 1 2345 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 37053 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15477 |
