I have a small quantity of bitumen to rip up with our new build. Who would I phone for quotes? Would they be able to do a saw cut on bitumen or does it flake?
Thanks for your replies
Browse Forums General Discussion 1 Jan 23, 2014 5:33 pm I have a small quantity of bitumen to rip up with our new build. Who would I phone for quotes? Would they be able to do a saw cut on bitumen or does it flake? Thanks for your replies Re: Ripping up bitumen - who do I call? 2Jan 23, 2014 8:33 pm Hi l would imagine they would use a jack hammer, and cart it away! A concreter would be my first call, they will at least give you a contact number to get a person to remove it! Good luck! Re: Ripping up bitumen - who do I call? 3Jan 24, 2014 10:31 am jack hammer not required. I would suspect you will just create holes with it. If you have a lot and its thick you can use a bob cat to lift it up. If you have a small amount have you considers lifting with a crow bar. Re: Ripping up bitumen - who do I call? 4Jan 25, 2014 3:21 pm B STAR jack hammer not required. I would suspect you will just create holes with it. If you have a lot and its thick you can use a bob cat to lift it up. If you have a small amount have you considers lifting with a crow bar. +1 . bobcat, excavator, anything with a shovel or bucket. Re: Ripping up bitumen - who do I call? 5Jan 25, 2014 4:09 pm Mrs Brown Bear I have a small quantity of bitumen to rip up with our new build. Who would I phone for quotes? Would they be able to do a saw cut on bitumen or does it flake? Thanks for your replies If you are going to keep some of the bitumen and you want a clean straight cut line using a demolition saw is best. That's the way the pros do it. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. |
