Browse Forums General Discussion 1 Jan 13, 2014 4:42 pm Hi All, New user here I just wanted to get your thoughts on a local concreting firm www.diamondcreekconcreting.com. I have had a pretty good price from them but needed some info about other work they may have done. With thanks, Kizza Re: Has anybody used diamond creek concreting? 2Jan 13, 2014 6:08 pm Just make sure they are putting the correct roe for the application and make sure they don't just put it on the ground and actually have standoffs. Get 3 quotes if they are the cheapest by far just query them. Sent from my iPhone using Tapatalk It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8381 We've had decent weather for last 7 weeks and now the drvieway has been cut out we had an evening of 50mm of rain including all the water from half the street, ground is… 0 4493 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9229 |
