Browse Forums General Discussion 1 Jan 08, 2014 9:22 pm I'm wanting to hang one of these Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ or similar... and then allow a couple of rather heavy kids play with it. (Right now they total about 35kg but they are barely 1 and 3 so this will go on to a good 50kg by the time they grow out of it if not more!) Any ideas on installation indoors? How to go about it? What suggestions to make it safe? I was thinking I'd install the hooks into a roof truss possibly cutting a hole through the ceiling if I had to (prefer not to). In a similar vein - hanging beds - any ideas on how? Re: How much weight could you hang from the ceiling/studs? 2Jan 23, 2014 2:25 pm I'd be creating my own little "panel" in the roofspace, where it will be supported across a few other beams to distribute the load. I would screw into the panel at least 2-3 different spots. One beam can definitely hold the weight, as when people stand on them it holds them fine. But i'd be more concerned about the single contact into the beam. If the screw pulls through, could cause some pain to the person sitting on it. Re: How much weight could you hang from the ceiling/studs? 3Jan 24, 2014 9:08 pm No advice sorry, but what IS that thing?? Build thread: viewtopic.php?f=31&t=65085 Re: How much weight could you hang from the ceiling/studs? 6Jan 27, 2014 4:49 pm EmyN it's a swing from Ikea It's good for small children - you can hang it fairly low to the ground (and inside or outside), and some kids respond very well to a bit of a swing as they hit the silly hour - mine being one of them. A swing is a given in our new home. Re: How much weight could you hang from the ceiling/studs? 7Jan 27, 2014 8:34 pm Intriguing. How do they sit on it?! Wouldn't they keep sliding off or their head get tangled in the straps? My boys would love it I'm sure! Build thread: viewtopic.php?f=31&t=65085 DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2155 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9613 7 12025 |
