Browse Forums General Discussion Re: Home built on a Sydney Water stormwater drain 8May 19, 2008 5:33 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Home built on a Sydney Water stormwater drain 10May 19, 2008 9:37 pm Contact the water and sewerage companies/authorities.
They normally have thier own pans on what what and where. Re repairing it - they should be able to do it from inside it as is - but if you go running dozers and trucks all over the place, I'd expect it to break or crack etc. at your cost. Steve Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8489 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7942 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4547 |
