Gday,
Just wondering if anyone can tell me how many horizontal noggins are in a normal 2.7m height studded timber frame,as some say1 and some say 2,anyone have a definitive answer?
cheers
steve
Browse Forums General Discussion Re: Number of noggins in 2.7m wall? 2Jan 02, 2014 7:23 pm Max noggin spacing is 1350mm so one should be fine in most 2.7 walls. I would use 2 for kitchen walls with wall mounted cupboards. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Number of noggins in 2.7m wall? 3Jan 02, 2014 9:45 pm Get yourself a copy of Australian Sandard AS1684 Timber Framed Residential Construction. You can either get it on line through SAI Global or from your local Tafe. If you are building a simple house in a non cyclonic area get AS1684.4 which is the simplified guide and is easy to use. You could obstensibly design you whole house from the guidance in the book and not require an engineer. I just built a timber framed home and it was the best thing to have in the tool box. But to answer your original question, Bashworth is entirely correct. 1 in 2.7m is fine. Re: Number of noggins in 2.7m wall? 5Jan 03, 2014 8:14 am It will also depend on your stud spacings. Our structural engineer used to have a rough guideline of one row for 450mm spacings and two for 600mm spaced studs but that was just a general rule of thumb that he wanted us to follow where possible. I'm unsure how that applies to the AS but the walls used to feel stiffer with two rows opposed to one. Stewie Re: Number of noggins in 2.7m wall? 6Jan 03, 2014 8:24 am teamfoc You can get the books at most Bunnies stores LOL. Stewie D that was just a general rule of thumb that he wanted us to follow where possible. I'm unsure how that applies to the AS but the walls used to feel stiffer with two rows opposed to one. Stewie I'll bet that he didn't work for a project builder. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Number of noggins in 2.7m wall? 8Jan 03, 2014 3:49 pm No, Bunglings won't have it. And it will be about $100. SAI Global is easiest. Re: Number of noggins in 2.7m wall? 9Jan 04, 2014 7:25 am Quote: I'll bet that he didn't work for a project builder. No, he was a general structural engineer with his own independent practice who worked for us and a lot of other local builders. Project builders as you know will always build to the lowest possible regs. Stewie Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5141 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16105 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6888 |
