- Potentially drapes also.
You really want something to stop the sunlight before it gets inside the house. Blinds/drapes will help a bit, but the heat is already inside. Ideally you would stop the direct sunlight hitting the window.
Browse Forums General Discussion Re: Should I mirror my design? Advice on house orientation p 41Mar 21, 2014 8:49 am housebythewater - Internal (automated?) blinds recessed into ceiling. - Potentially drapes also. You really want something to stop the sunlight before it gets inside the house. Blinds/drapes will help a bit, but the heat is already inside. Ideally you would stop the direct sunlight hitting the window. Re: Should I mirror my design? Advice on house orientation p 42Mar 21, 2014 2:58 pm housebythewater I'm a bit late to join the fray, but thought I'd dare offer you a little support! I wonder if you have already made your decision. We will also have a double height void above our living area with large windows. The windows will face more NW and we are not flipping the plan because we want to maximise our view. Here's what I have in mind for us: - Internal (automated?) blinds recessed into ceiling. - Potentially drapes also. - Strategically plant shade tree to partly shade windows in Summer. - Plenty of windows that open upstairs, including in the area shared with the void space. If that all proves to be inadequate, I will consider a wooden (or wood-look) slats screen on the exterior, but I don't expect I'll need to go that far. We picked the design because we love the big open space and the view it affords. I know that the West sun could potentially cook us, so I'm planning accordingly. You may not have space for a good shade tree, but there are some stunning shade screens these days. There are plenty of ways to create shade. Good luck. We decided to flip the design so it will get the morning sun instead. Unlike you, we don't have any views. We intend to have motorized blinds to begin with and will see if that is sufficient. Btw, I had a brief look at your blog. You have a great blog and I really liked your house plan as well. 0 617 DIY, Home Maintenance & Repair Ditto 3M Claw, expensive but best thing I've used to date. I put two of the 11kg ones in for a 12kg mirror on the wall, and its been great for 4 years now. 4 2146 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17956 |
