Browse Forums General Discussion 1 Dec 19, 2013 3:15 pm I was about to put a new light into our bedroom and in the process checked which of the two wires was the 'active' one. While doing this I noticed that the active is actually not being switched at the light switch at all, the 'active' pin at the light bulb is always active. So I assume that the 'neutral' is being switched as the light can be switched on and off ok. Is this usual? Coming from Europe I'm surprised to find a switch which does not switch the 'active' wire for a light. Is this in line with Australian regulations, or WA regulations (whichever applies) as we're in Perth? Appreciate any help as we've just reached the 6 month warranty point and I'd like to raise this if it's not right. Cheers. ~~~~~~~~~~~~~~~~~~~~~~~~ Building with Redink in Madeley WA Photos: http://s1244.photobucket.com/user/takat ... yHouse2012 Moved in 01/06/2013 Next project: Lanscaping Re: Light socket is always 'active', won't switch off 2Dec 19, 2013 3:31 pm Raise everything - and put it in writing. Regardless. Re: Light socket is always 'active', won't switch off 3Dec 20, 2013 9:35 am Are you an licenced electrician? If not be aware that you're breaking the law and voiding your warranty and your insurance if you're doing electrical work. If you're just changing a globe then please ignore above and do like Mike says. Re: Light socket is always 'active', won't switch off 4Dec 21, 2013 6:19 am Sounds like incorrect wiring as the active should return to the switch before going to the socket - and as you say, your wall switch will still operate, but it will leave a dangerous situation at the socket (take care when changing light globes and don't use a metal stepladder) ... in Europe I did all my own wiring and the authorities checked it, and connected if it was to standard. Similar for plumbing, here we need a licence. Sounds like we should all have our light sockets checked! Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1217 I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3119 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9075 |
