Browse Forums General Discussion 1 Nov 30, 2013 7:36 pm I've been hunting around for some decent acoustic batts to place between our bedroom and ensuite and also bedroom and kitchen (hubby is a shift worker) and I've decided on the R2.1 70mm Sono Batts. I was originally looking at the thicker R2.7 90mm batts but the sales guy on the phone said that they're not good for internal plaster walls due their density - they'll end up warping/bending the plaster Has anyone used these batts before? Do you think they work well with deadening the sound? Would you recommend another brand instead? Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Pink Sono Batts Soundproofing batts 2Dec 03, 2013 2:40 pm Quote: they'll end up warping/bending the plaster Not if you use two layers of 16mm plasterboard with the joins offset which will almost guarantee no sound transfer. The batts on their own will make some difference but probably not as much as you'd like. How big a wall are you talking about ? Stewie Re: Pink Sono Batts Soundproofing batts 3Dec 04, 2013 6:48 pm Thanks for the response Stewie The wall isn't huge. It's 4840mm x 2700mm high. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26171 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11666 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9157 |
