Browse Forums General Discussion 1 Oct 10, 2013 2:00 pm I live close to Ryde area in Sydney NSW and I am trying to put in a new plain concrete driveway which means some excavation work is involved. I am trying to build something that is solid but not too fancy. As the work is done closer to the boundary with next door neighbor I also have to be careful where we are pouring concrete hence I am in the process of doing a survey. Is there any recommendations in terms of good driveway concreters that may also take care of excavation work? (if anyone has experience in giving any jobs to these concreters?) Is there anything I need to be aware of when getting a quote and picking the right concreter? Thanks for your help. Re: Driveway Concreter Recommendation - Sydney West 3Oct 14, 2013 12:58 pm Any decent concretor will have contacts in the earthworks industry, so get them to arrange excavation it if thats what you want. They know exactly how they want it excavated anyway, As far as "good" concretors go, there is not much that can be stuffed up on a 100mm thick concrete driveway. MPa25 mix, 7.2mm mesh, poly sheeting laid down at a minimum. Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37758 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10902 If you need to pay for a project manager you would be well advised to just engage a builder who would take full responsibility for the build. As opposed to you OB where… 5 15128 |
