Browse Forums General Discussion 1 Oct 09, 2013 9:40 am I would like some advice before I approach my builder. Hubby is extremely upset that there appears to be no 'flashing' on the windows. I have found conflicting info on the net about whether it is required or not. We are building rendered brick on the ground floor and Hebel on the top floor, our windows are aluminum. Many thanks Re: Quick Question ... Flashing for Windows 3Oct 11, 2013 9:05 am You say rendered brick below and hebel for the top floor but are you talking brick veneer ? If so then yes, flashing should be used to keep water off the timber framework. It may not be required by the regulations ( BCA with caveats ) but it is still good building practice. The head flashing may be exempt by eaves overhang but I very much doubt the sill flashing would be. A few measurements of the sill height, head height and eaves overhang plus a photo as 33amc above asks would help. Stewie Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a… 0 10932 I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10629 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 |
