Browse Forums General Discussion 1 Oct 07, 2013 8:03 pm would someome pls advise me which profession is responsible for building a new roof ? the roof is leaning to one side and have been advised that the whole roof timber needs to be replaced. Apparently the tiles can be removed and placed back on as im they are in a good shape and cost a lot to replace, but if theres no need to replace them I prefer to reuse the old ones.. Thanks Re: new roof 2Oct 10, 2013 9:12 pm you would need to employ a licenced builder unless you want to coordinate your own roof tiler and carpenter seperatly as the work required is over 2 different scopes of work. you need to contact a licenced builder if you dont want the hastle of planning and managing different trades yourself 2 9450 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4214 |
