Mosquitoes at the front door
I was wondering if anyone else had this problem and whether there were any possible solutions to this. I have tried placing a bug catcher there but it did not seem to make a difference.
I have thought about:
a) Setting up a fan (don’t know if it would work)
b) Installing mesh doors to block off the area (expensive)
c) Installing a fish tank (don’t know if it would work)
d) Spraying poison (don’t know if it would work and/or how healthy it is to be breathing it in before walking into the house.
e) Not using the front door….(?!?)
Does anyone have any ideas or suggestions?
I would try to ascertain why you have such a large concentration of insects around the door. Do you leave a light on at night? (which will attract them) It there any stagnant water nearby? (where mosquitos will breed). Are there any fruits/vegetables/fungi nearby which the gnats may be attracted to?
If they are mosquitos I would think something as simple (and inexpensive) as a citronella candle would help to deter them. If they are gnats I'd just wait until they decided to move on to somewhere else.
Hope that helps
The fact that they congregate around the front door is a clue and the first thing that I would be doing is checking your guttering for ponding in this area. Once the larvae emerge as adults, the gutter will no longer be their home and they will move to somewhere hospitable nearby.
Most new homes have roof drainage that is designed for aesthetics rather than function and this is why many new homes do not have downpipes at the front. The distance between the downpipes then causes issues with inadequate slope, particularly as the house settles. Mass numbers of new homes are built and sold with non compliant storm water drainage. It is endemic.
If you also have a rainwater tank with a wet system, you need mosquito proof leaf diverters fitted to every harvested downpipe as well as flaps on the discharge pipes above the tank's top meshed inlet to prevent mosquitoes from accessing the water and breeding. Both of these devices are mandatory in many areas but they should be mandatory everywhere.
Mosquitoes also breed in plants that capture and retain water. A mosquito lays between 200-400 eggs in a raft and they emerge as adult mosquitoes within 10-14 days.
12
AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,…
26/04/2024
4
920 was enough to get the furniture in. We live in a pretty safe area and it’s great to see people walking to the front door. We’re not too fussed about people…
25/05/2023
1
Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off
