Browse Forums General Discussion 1 Sep 29, 2013 2:14 pm The entry and lounge in my house have boards on the wall (probably original from the 1920s) diagonal to the chair rail then horizontal up to the 11ft ceiling. There are a lot of gaps that have appeared between the boards. Some happened after I had the floor relevelled. Others have just appeared and I suspect it is because of recent warm weather then cooling in the evening. The previous owner has filled some gaps with a plasticy stop gap stuff - this has cracked. I used a multipurpose filler on a few gaps as a test but this has also cracked. What do I use? What do I do without taking off the boards or gyprocking over them? posting.php?mode=post&f=1# Re: Fill/fix gaps in wood paneling 2Sep 29, 2013 4:10 pm Without seeing a photo of them I'd suggest some kind of gap filler like No More Gaps and just painting over them. If they are really bad you can either replace them or do as you say and gyprock over the lot. Stewie DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 8941 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5313 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7505 |
