Hi,
I live in Beveridge and I was just wondering if anyone has a figure in PSI as to what the recycling water pressure is...
Thanks
Browse Forums General Discussion Re: Recycle Tap Water Pressure 2Sep 23, 2013 11:54 am Your water supply utility should be able to help with information. Mains water is now regulated at a maximum of 500 kPa for new homes. Recycled water is delivered at a bit less than this. If pressure for garden watering is a concern, just buy an 18 mm hose and join a short length of 12 mm garden hose to the end so that you can still use the standard 12 mm hose connections. This will substantially reduce friction loss and deliver plenty of pressure. Cisterns are regulated to fill at 6+ lpm. There will be plenty of pressure for this. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1670 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16861 |
