Browse Forums General Discussion 1 Sep 21, 2013 9:06 pm Hi everyone I am going on holiday for 4 weeks and to avoid a possible water pipe leak (which happened once before when I was home) would it be OK to turn my water off at the mains? Also if i do that, will I also have to turn my electric hot water system off as well? By doing this would it cause any forseeable problem when I turn them back on when I come home? ie. does one have to be turned on before the other or would it cause a problem I am not skilled enough to think of? Any advice from someone who has done it or is qualifed to know the answer would be much appreciated. I live in Perth. Sky... if it's the look that you're not happy with, the easiest option would probably be to spray paint it all into the same color as the walls so it blends in. there might not… 3 4192 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14076 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1548 |
