Hi all,
Just after a bit of advice. I am looking to paint our house, but also wanting to clean up some of the previous owners dodginess at the same time.
The house is a weather board clad home, and while the boards are ok for the most part, the corner pieces (plastic mouldings) do not completely cover the boards in some areas as the boards are not quite long enough, and miss the cover by between 10-20mm at the worst points. While there is only 3-4 boards that do this, it is on the front corner of the house so it is one of the first things I see ever day. The white 90 degree angle corner trims on the '4 corners' of the house are what I am refering to. The current ones look to be around 50mm x 50mm. These are simple 90 degree, nailed over the top of the weatherboard, and do not embed the boards themselves.
So my 3 questions are as follows:
1. What on earth are these called?
2. Can you get bigger sizes, like 80-90mm?
3. Any suggestions of where i can find them? Bunnings has something similar to what is on the house at the moment, but I need bigger
Thanks in advance
Cheers,
Anthony
