Browse Forums General Discussion Re: Drainage\Sewage for property - Help! 2Sep 06, 2013 1:10 pm Building McDonald Jones Bronte Manor One Contracts Signed Dec 12 DA Lodged Jan 13 DA Consent w/BAL40 Apr 13. S96 Consent w/BAL19 May 13. Slab Complete Jun 13. Frame Brick & Roof Complete Aug 13. Re: Drainage\Sewage for property - Help! 3Sep 07, 2013 6:29 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Drainage\Sewage for property - Help! 4Sep 07, 2013 1:09 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Drainage\Sewage for property - Help! 5Sep 09, 2013 9:15 am Hi All, Thanks for all the great responses. There is actually a development taking place about 10 houses up the road and they are putting together a duplex build. My draftsmen recommended i try and contact the builder and see what they were required to do as that could give me a better indication of what to expect. In saying that SaveH20 it sounds as though this is your area of expertise? Can i take it this is your line of work and if so do you have contact details should i need to follow up further? Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12283 2 5845 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3148 |
