Browse Forums General Discussion 1 Aug 21, 2013 5:38 am Just wondering why australia requires tapware to be made from dezincification resistant brass where other countries eg. Germany where all the highest quality tapware is made does not. Do we have particularly high levels of zinc in our water? Would it be highly detrimental if we did use tapware that didn't have dezincification resistant brass? Re: Why are australian standards on tapware so strict? 2Aug 21, 2013 1:06 pm WaterMark certification was formerly under the auspices of Standards Australia, a private company. This was a highly undesirable situation in my opinion but it now comes under the Australian Building Codes Board (ABCB). It is possible that the transition is still to be finalised; I am not sure. The ABCB will, I am led to believe, be examining a number of certification issues and I think that it would be best served if you directed your query to the ABCB. watermark@abcb.gov.au 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Thank you fro your response, Simeon. It is good to hear that you have had a positive experience with Parisi. I am always on the lookout for reliable products, and personal… 2 4326 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6996 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5145 |
