Browse Forums General Discussion 1 Aug 03, 2013 10:27 am Hello there, we thinking building barn house to lockup on Macleay Island instead. Finding the cost to pull out maybe 4 trees on the block. 890sq. Or we will chop the trees down and they removal the stumps. No one give me some idea of what it would cost. Even if they level the block. Its on a slight lean but mainly flat block. does anyone have any ideas what would cost. Re: Earthmoving equipment. Cost clearing block. Macleay Isla 2Aug 04, 2013 2:12 pm A 16T dozer will knock over 4 mature gum trees and put them in a pile for you in one hour easy. You can get them at $180+ ph on the mainland. Your big cost will be their travelling time to get over to you. do not chop the tree down - the dozer will grub out the roots, then just push it over. It prefers to have the full weight of the tree to do that. DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 6 11144 Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 33666 |
