Browse Forums General Discussion 1 Jul 29, 2013 11:25 am I have a painted plywood door (i.e. two sheets of plywood, empty space between) to which I want to attach an automatic door seal. I am worried that if I attach the door seal using the nails provided that the plywood will just tear off (as it is not very thick). I was wondering if I attached it with liquid nails whether I would have the same issue or which this would stick OK? Also would I have to sand back the paint (so that the glue was adhering directly to the plywood rather than the paint)? Re: Attaching an automatic door seal to plywood 2Jul 29, 2013 5:07 pm Usually auto door seals like this one -- http://www.raven.com.au/domino/raven/rp ... enDocument are attached by small screws (provided) to the bottom 30mm frame of the door, unless the door has been drastically shortened at the bottom. Arfur Re: Attaching an automatic door seal to plywood 3Jul 30, 2013 1:42 pm Yeah, that is the one. I can't tell how large the frame is though (by knocking it etc) and so am not sure that I would be drilling into the frame (as opposed to just into the plywood). Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4046 DIY, Home Maintenance & Repair Follow up question - any ideas on how to set up a portable air conditioner through this kind of window? 1 6230 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 652 |
