Browse Forums General Discussion 1 Jul 28, 2013 5:35 pm The grout has failed on the shower floor in one of our bathrooms. This is the worst part. There is a distinctive line that runs the length to the tiles so I'm pretty sure water is penetrating - have stopped using this shower just in case. Landscaping yes - Tiling NFI. Any help would be greatly appreciated. http://i459.photobucket.com/albums/qq311/EB_Photos_2009/7d3b27488418995afe85eddc0d0ae74f.jpg Re: How do I fix this? 2Jul 28, 2013 6:37 pm Just top up the grout. Grout won't stop water penetration, that is why there is waterproof membrane under tiles. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: How do I fix this? 4Aug 04, 2013 8:54 pm You might find it hard to find a tiler that's likes doing little jobs like these. It is something that you can have a go at yourself. For about $20 you can get a diamond grout removing tool and the same colour grout mix. Re: How do I fix this? 5Aug 07, 2013 12:15 pm FCS You might find it hard to find a tiler that's likes doing little jobs like these. It is something that you can have a go at yourself. For about $20 you can get a diamond grout removing tool and the same colour grout mix. Yep I guessed as much with regards to the size of the job. Going to have a go myself. cheers DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5977 Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39049 |
