Browse Forums General Discussion 1 Jul 14, 2013 10:13 pm Hi all, Does anyone know what the external black cladding system is on "The Block"? I'm assuming it would be a metallic system rather than timber as maintenance would be impossible on it if it was timber, but i really like the way they've split it up into the horizontal and vertical blocks. Cheers, Luke Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12002 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11106 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5617 |
